Farmall B Carb
nelsonm0099
Putting together my first Farmall B. I put a rebuilt carb on it. I can get the engine to run but the carb leaks fuel into the air intake until it starts. Is this an issue with the float, the bulb, needle adjustments, or just normal?
Could be the float is sticking. If not, use very little or no choke when starting, then after it starts be prepared to close the choke about half way to keep it running. Basically all letter/hundred series carbs act like that.
