Farmall B Cultivators?
tshlance
I want to find/buy cultivators for my Farmall B. I would like to use the tractor for my garden. How can I find the cultivators? Are they specific to the Model B?
I have been searching the net for "Farmall B Cultivators" and have seen plenty of them for c's and a's but no b's.
Thanks in advance for any help.
tshlance
Any more finding cultivators can be like finding hens teeth. Due to the fact so much stuff has been scrapped and the fact they are not used much if any any more they are few and far between. I sold a set a few years back to a guy in N.M. and he drove all the way here just to pick them up. That is also the only set I have ever run across so far. You do also pretty much need to find a set for a B since they are made just for the model and mounts are not the same on them all
Thanks.. I was hoping someone would confirm each model is different. Sounds like I have a uphill climb getting the implements..thanks
How many do you want and which lift system. Where is your location. I am in eastern IOWA. There is three lift systems for the B-238 I also have a B-221. 319-430-3907 CELL#
I am in Brenham Texas.
I am not sure when you ask how many. I am looking for th complete set. I just have the naked tractor.
I would like a manual lift. I don't want to worry with the exhaust lift thing.
Yep in the years I have been on here which is more then 10 I have seen maybe 3 sets up for sale and that covers the U.S. And from what others have said things made for a B are pretty much the only tractor they fit or if you have an A it works the same way
Keep watching the adds as there have been some on there last one was a week ago. I had some a month ago and no calls. Finding one complete is the problem.
I also think a lot depends on where you are as to finding them. In this part of Missouri it is very hard to find things like cultivator but then there has never been much row crop farming in this area
Dear tshlance: From Wm Eccles - Jardine
I have a full set of cultivator scufflers for my BN which I will
gladly part with.
To adapt them to manuel you need to add extra springs to
the system. I did use them in maually mode one year before I
stored them in the shed slightly more convenient way is to ad a
hydraulic pump to the end of the pulley at the front or a side car
pump to the extra pulley on the front of the engine. simple
bracketing and belting.
I am asking 375 Canadian plus shipping [ would find the
most direct least expensive long distance haller. several in the
area.] area code 1 519 285 3854 Thamesford Ontario Canada
N0M2M0
{2 hours west of Toronto 1/2 hour east of London] for location.
The manual lift levers which there were two models arent the same as the levers for the exhaust lift and adding springs just wont do it there isnt enough throw on the exhaust levers to lift the cult out of the ground and the spring on the exhaust lever is for lowering and not lifting so adding springs just wont work.
