Farmall B electrical issue
FarmallB1945
Hi all
I recently was running my Farmall B, when I had shut the tractor off I had noticed there was smoke coming out of the electrical box below the throttle assembly. After I started the tractor back up to pull it in the shed to further investigate what happened, it ran just fine for that short while then unhooked the battery and let it sit for a day. When I came back I found that the wire coming from the relay on the generator had been burnt. I also started the tractor again to find out it was missing on different cylinders. I pulled the distributor apart and found that it was making poor or no sparks when it should be. I am stumped and appreciate any help you are willing to give.
