cuttman
does anyone know the wiring diagram converting a 6 volt to a 12 volt. I'm using a Delco 10SI alternator,an ammeter and a toggle switch for the kill switch. I also have a wire coming from the magneto. this is on a farmall b
there are thousands of posts and diagrams in past posts on this subject.
DO NOT under any circumstances hook that wire from magneto to a power source...you run that wire to toggle switch and the other post on toggle goes to ground...toggle will say "ON" to kill tractor. "OFF" is where tractor will run.
