Farmall Blade
Hey! I saw this on facebook marketplace when i was looking for a blade for my super a. Could this work? It looks like it is missing a lot of parts...
https://www.facebook.com/marketplace/item/434217278794965?hoisted=false&ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3Ae8741b3f-1506-4da4-8c92-89fd2c032225
For sure it is NOT an IH blade designed for the Super A.
Looks like a generic snow plow for a garden tractor. Possibly home built. Are they calling it a Super A blade?
If it's wide enough, and built heavy enough, and you can build the pieces to figure out how to mount it. there's no reason it wouldn't work.
The blade I built several years ago. It attaches to the rear final drives with bolts and the lift is attached to the right touch control arm. If the link to the touch control arm is rigid, instead of a chain, you will have down pressure on the blade which is very beneficial.
I cant find any more pictures but it is basically a 2 x 2 tubing with 1/4 wall thickness rectangular frame with some cross bracing for strength. The blade is 1/2 plate that was formed by a local iron workshop.
If you make one, make it as strong as you can because you will be surprised what you can do with it.
That's a Wheel Horse plow, works good on a Wheel Horse, might fold up being pushed by an A.
A garden tractor blade and I had one off a Wheel Hose was going to try to put on a Cub cadet, dever got it done. will be only about 3 to possibly 3 1/2 foot wide I don't know width of a A or Super A but dought if even a 5 foot blade would ba as wide as the tractor. And to angle would take a 6 foot blade.
have a blade that would fit your tractor, might need some minor mods.can send pics to your phone. 150.00 located in utica n.y thanks earl
