Ken Hansen
The other day I noticed the right front tire looked soft, sure enough aired it up and air came out almost as fast as it went in!
Drove left tire up on a block of wood to let me pull the right side. That's when I noticed the slop in the wheel bearings. Dang guess this is going to be a little more work!
Pulled the three bolts and removed the cover, not good very rusty. I was a little surprised as this BN lives inside year round when not mowing the lawn and only occasionally has it been hosed down with garden hose.
After removing the right wheel jacked up front end and sure enough the left side is also loose. Left that on for now as at least I can move the tractor on one wheel if needed.
Checked a couple sources for bearings and seals online and they all seam to come in close to the same so I decided to give Yesterday's the order as they are good to run this forum for us.
While waiting for those parts I can get to fixing the flat, turns out it looks like I may have pinched or damaged the tube when I had installed the "new to me tire" last year. Put a patch on it and will see if that holds up.
By the way not sure if anyone else has done it but I am running a pair of "Temporary Spare" car tires for front tires. I got one for free and the other at the auto recycler I think cost maybe $15.00. For the use mowing they seem to work find and don't dig in on the soft ground when making turns.
