Farmall C Hydraulics
SDP1
I am adding a bypass block between the touch-control reservoir and the remote control valve so I can use the fast-hitch. The old gasket looks to be a paper-type. Can I just make two paper gaskets for either side of the bypass block when mounting this? Any other advice would be great since I don't have a manual for the hydraulics.
It is just a paper gasket. I made one when I removed the priority valve from my Super C and put on my C. The hard part is getting the old gasket off of there. I finally pulled the lines to the pump off so that I could get it clean. The flange on the pump are just o-rings. I got lucky and the o-rings did not leak on me.
