Dougct
I will be new to stock pulling this year,but not to tractor's.I will be running a farmall C.It has a super c kit.Not looking to to be on TV just have some fun.Right now it has the original 9 tires on it.I want to take them off and put them aside.What rim and tire set up will be decent to run on my stock center's?Thanks
with that set up 11.2X36 that are found on a Super C / 200 / 230. 10" rim. The 36" rims are hard to find used and new they make limited widths. If you want larger you have to cut and weld in a spacer. However any tire larger then 11.2 will really pull down that engine. For you are working with the 11.2 on a stock Super C rim will be the right combo.
Andrew
You might want to try those tires before setting them aside. You might be supprised. I only pulled my Farmall C four times and it has the narrow tires. Got three firsts and a second in the 3000# class at 3.5 mph.
Just curious on something AT.Is anyone going to let you pull that Yellow tractor,because all the rules I have ever seen you now have a Home made tractor.You can't call it a C because there never any Farmall Cs made in that rear end configuration(or anything that looked that way) and can't call it a 204 because it would then be too new.With all your past troubles,I hate to see anyone spend good money and time on something that is not and never will be legal except maybe,just maybe in Div.5 classes or exhibition only.If they do OK it, then good luck pulling.
You are right on the axle rule thing. What I was getting at was,If I would take an H,put a 264 motor in it and W4 axles,what would I have?(An H transmission tractor)(Home made).If you get by with it,then like I said Good luck and many good wins.
