farmall carb
guest6789
Couple questions.
Who sells different venturis?
Are venturis interchangeable from an M carb to a W9 carb?
A W9 carb would seem to be the way to go in a big engine, but is there any advantage to the big carb and big throttle plate on a 281 engine if you were to keep a small venturi?
McDonalds carb and ignition sells Venturi's . if you don't increase the cu.inches or compression the original will be fine.
