Farmall Cub
rbrock2004
Problem with the throttle jumping out of place slowing the tractor. I have replaced the spring on the throttle still jumping out
of place. anyone have any ideals what can be done to have throttle stay in place
Sounds like your throttle control is worn were the lever catches on the saw tooth part of the plate. I have worked on them with a file or small cutoff wheel on a die grinder and fixed the problem. There will also usually be wear on the catch on the lever itself. New ones are available.
We had this issue with our cub and A, little bit of weld on the handle, ground it to shape and filed the notches. Both work great now. Gotta doctor up the M throttle handle next.
