Farmall f-30 float height
turn the top of carb upside down, with float resting on needle and set the float level and that is all there is to it. there is nothing critical in the float setting. a 1/32 either way will not affect carb operation. but if your way too low you will be running out of gas on a hard pull. all carbs are set the same. float level is where you want the float when sitting in the float bowl.
