Farmall Gear oil
Farmall Joe
Hi my Farmall is running smooth now!!
the only problems are there is a small amount of oil comming out from the base of the stick shift. And the radiator is leaking.
Is this normal can I get some radiator sealant
Joe, not knowing what model tractor you have but if oil is leaking around the gear shift I would think the transmission/rear end oil has water in it. Try cracking the drain plug after letting it set a few days. Change if milky looking. Stop leak will keep water from leaking out of the radiator but don't know for how long. Weigh the difference of having it repaired vs how long you plan on keeping the tractor. David......
