Farmall H cam
David Terry
I replaced my old cam with a used one including a used gear. The replacedment gear has two dots on it. One is heavier than the other. When thew heavier one is lined up with the crankshaft dot, the lighter dot lines up with the idler gear. The number one journal on the crank in this configuration, is laying horizontally. Should I be aliging the big dot with the crank, or the little one?
