Farmall H clutch
Jziemer
I need to put a new clutch in my Farmall H. It has a 10 inch disk in there now. I'm wondering if I bought a 10.5 inch clutch disk and pressure plate assembly if that would work?
Find out if the pressure plate hole pattern is the same as the 10 inch. I see some Rockford 10.5 clutches on here. Hal
Ok thanks for the help. I have a super H flywheel in the shed and was thinking about getting the 10.5 dis and pressure plate and put that in. Not sure which one will end up in it yet. But thanks for your advise and opinions.
