Farmall H ditributer
James MN
The distributer on my H is origionaly off a 350 the ditributer has a hole in it for mounting the tachometer cable but my H doesnt have tachometer. I want to find a cover for this hole. Does anyone know where I can find one? Thanks
Here are the part numbers of the CaseIH website for a 350 Gas tractor.
You can double check yourself to be sure at caseih.com
Randy
14 1 363765R1 GASKET GASKET, distributor drive housing hole cover (used with 363763R11 on tractors not equipped with tachometer)
15 1 363764R1 COVER COVER, distributor drive housing hole (used with 363763R11 on tractors not equipped with tachometer)
2 435429 SCREW, machine, slotted-rd-hd., cd-pltd., no. 10-32NF x 9/16"
2 120217 LOCK WASHER WASHER, LOCK, #10
