Farmall H engine
ziemerj
The current block I have for my h is cracked. I found a super H engine that is complete and running to put into my h. As far as I can tell it should bolt right into my h. The super H engine doesn't come with a flywheel. Will the fly wheel and clutch from my H engine work on the super h engine? Are there other things I may have to change to make this work? Thanks in advance.
H flywheel will work, rest is a bolt in except if it has the original SH carburetor the choke rod needs fitted to a different side and the air cleaner outlet and tube is smaller so the original type hose connection won't fit to the carburetor inlet without changes.
