Farmall H flywheel
I inheritd an H with a bad flywheel. The tractor runs like a top if you give it a pull but you cannot start it with the starter because the flywheel is all ground off.I belive you have to split the tractor to fix this correct? and if so can anybody tell me from experence the best and easiest way to do this. Thanks, Travis
(quoted from post at 21:10:49 08/27/07) I inheritd an H with a bad flywheel. The tractor runs like a top if you give it a pull but you cannot start it with the starter because the flywheel is all ground off.I belive you have to split the tractor to fix this correct? and if so can anybody tell me from experence the best and easiest way to do this. Thanks, Travis
Yep...gotta split it.
the flywheel starter ring is replacebale, you dont need to junk the whole flywheel. steiners sell em for about 40.00 or so. you can either heat the old ring to remove it or break it with a chisel. heat the new ring a little to expand it and it drops right on.
