Farmall H questions
RMOMN
Two questions is there a keyed on off switch available and what size wire do I want to rewire the lights it"s still 6 volt. (My tractor is 275 miles away)
Any two terminal key switch with a 10 amp capacity will work. The hole in the box is about 9/16" diameter. If it has a mag. the switch will need to be grounded on one terminal to work. if it is point and coil distributor, it will need power to the first terminal of the switch.
If mag, it will be on when the switch is open, and if distributor it will be on when on and off when off.
12gauge wire is conservative and appropriate. Jim
