Farmall H Sleeve Puller
Gents,
Looking for a sleeve puller puck for my H to pull the sleeves. What is the OD of the new or old sleeve to be installed. I understand the 3 3/8" std bore sleeve and the 3 7/16" overbore sleeve. What is the OD of the sleeve?
Thanks,
Brady
Can you measure the cylinder bore diameter of the block with the old sleeve installed? You may be able to measure the block bore after removing the piston and connecting rod. If the sleeve doesn't extend all the way down to the bottom of the block. Hal
PS: Use a pair of dividers to get a close measurement.
you could measure it at btm with calipers if possible. puck has to be a few thou. smaller than the o.d. of sleeve. I just take an old sleeve to the machine shop and they build the puck to fit.
100.00 dollars later you have one.
Contact Federal Mogul tech service at 1-800-325-8886. They may know what the block bore is for the H. Hal
