Farmall H, what mounts here?
Cisco
What are these mounting holes on the steering bolster used for?
There is a bracket that bolts on with 2 pins for the brace rods to a front mount cultivator for our H we also had a gflat about 6 inch board that bolted on in place of it for a front mount deal to lift the buzz saw in the winter. It had t2 braces that angled back and bolted to the frame rails. A hydraulic cylinder was pinned on it for the buzz saw.
My good friend, that is a 2 row cultivator. Row crop
cultivators are used to control weeds between crops
planted in rows like corn. My self and others on here
have hours of experience operating one of those on an
old Farmall days on end. I am linking the YT post that
the picture Jim posted came out of. There in the photo
taken straight on from the front you can see the gaps
the crop would go through and also the metal shields
that kept the dirt from rolling over and covering the
small plants especially when you go over the crop the
first time when it is real small. The ones we had in the
farm in Kansas had a rolling disc on each side of the
riwto push dirt up near the row at the base of the plant
stalk. Covering weeds was one method of de-weeding
the crop right near the base of the plant where the
roots could be damaged.
More pictures
I never plowed (cultivated) with a 2 row cultivator, always a 4 row front mounted cultivator. SUPER M-TA and
IH #455 cultivator, 450 and a #468, and used a 4010 with Deere #400 frt mount a couple years. The SM-TA and
450 pretty much tied for ease of cultivating. 4010 with WFE would not turn tight enough to take the next 4
rows, had to skip 4. The power steering hand motor needed rebuilding, and the steering wheel would turn right
about half a turn going across a quarter mile long field, full turn on our half mile rows. Hard to believe a 5
year old tractor could be so worn-out.
