Farmall H won't roll
41 H, split and new clutch. Pulled transmission cover pulled rear axles as gaskets were leaking. New axle seals and gaskets and pto seals. With tranmission cover off, everything rolled free. Have cover on, and tractor back together and tried to roll and it won"t roll. Brakes are adjusted properly, belt pulley disengaged, transmission gear shift lever is in neutral and pto disengaged. I am afraid I will have to pull the cover off- what do I need to look for. To the best of my knowledge, the shift forks were in correctly.
Quite possible that the shift rails are out of line. You can remove the belt pulley and line them up. Also possible that you moved one of the gears during installation.
