I'm a new Farmall H tractor owner. The tractor was running fine back in the spring, although it never started great, it did start. Now, I cannot get my H to turn over, even when attached to a battery charger with the charger set to engine start (100 amp). The battery measures 6.93VDC when not connected to anything. I replaced the starter with a rebuilt one from Amazon, still won't even roll over. I bench tested the old and new starters, connecting (+) battery post to the starter housing and (-) battery post to starter connection post. I momentarily touched the (-) lead on the battery to test. Nothing happened with either starter (connected same way). Is this a battery issue?
If I buy a new battery, I will do the conversion to 12V, as I want to permanently resolve the starting problem. Can I use the 6V coil if I add a dropdown resistor? Any recommendations and source for a good 12V alternator that will fit?
