mintenfarmer
I have been looking and cannot seem to find a wiring diagram for an h with magneto, generator, voltage regulator, and four position light switch. Does the vr not work with the four position switch? If it's possible, could someone post a picture or message me one?
Yes the vr works with the gen on the H if you got the one made for that generator not just any reg will work with that gen as it has three brushes and the positionand load on it determines the charge. Is the gen original and what is the last three #s on the tag.
I don't know the tag number at the moment, but I know that what is there worked at one point. I just don't know how to wire it because I did not take it apart or have the old wire to look at.
Maybe this might help.
THey cannot be used at the same time. Either use the light switch (and your memory to reduce charge when running) or the VR.
Neither will work if used together. All Regulators for this vintage Delco systems) have a cutout relay internal to them. The Arm
terminal and the Bat terminal are the only ones used, and the regulator must have a good ground to the tractor or generator. The F
terminal is not used at all if the light switch is used. Jim
