wildhog
I have a h farmall and can not get it to fire had trouble a while back with the on and off switch question does it ground to make it fire or ground to shut it off is there a way to test the switch im sure it has something to do with the switch thanks
If it is a magneto it opens and un shorts to run, if distributor it closes and provides power to run.
A very simple thing can stop an old Farmall dead. I've had it happen to me. When the center electrode inside the distributor cap gets worn down enough, you can crank and crank all day long, and she'll not fire. I've had t happen. Just replace the cap and the rotor, she may fire right up. Very cheap to do. BTW, get the cap with the COPPER BRASS insides, not the aluminum.
so if I disconnect the wire from the switch or mag it should fire right now im getting nothing from the mag
With the wire off the mag, it should fire. If not dress the points with fine emery cloth and clean with a folded dollar bill. (no lint) The gap setting when points are open is .013" If no joy, make sure the wire from the mag coil and condenser are not touching metal in the mag. Jim
