Kawookie
Hi, I have a farmall H with the motor out of it... Crack in the block around the ring,, mechanic man says cant be fixed, and need to look for a used block,,, question is,, is there a diesel motor that would be compatible with the H frame?? Or am I dreaming... Thanks
The Continental in a Farmall 350 might fit with some work. Perkins also made a conversion kit to put the P3 in a H. That would be another engine option for you to consider.
Mike
