Andy Motteberg
Hi,
My 1943 Farmall H runs good, except when you speed up the engine, it kind of sounds like it is going to shut off, it kind of spudders then it runs fine after that when its speeded up. Why does it do this? It has never done this before. The tractor usually only starts with the throttle all the way down, if it is in the middle or speeded up, it won't start, it will smell gas and not start, think it might be flooding or something. It starts and runs fine when the throttle is all the way down, but it also does not run as slow as it should when the throttle is all the way down, when it is all the way down, it runs like it is in the middle. The carburetor throttle shaft is engaged with the governor shaft tooth. I hope you can understand this!
Thanks!
Andy.
Thanks!
Andy.
