Maestro
Recently restored a H farmall tractor. It sat most of the summer before I just got it painted etc. Now the darn thing won"t run cool. I have Zero circulation in the radiator. Had the water jacket cover off the side when I replaced gaskets. It was rusty but we cleaned it all up. Put a new thermostat in today and put a little piece of wire in the water pump hole and turned the fan to make sure water pump ws turning. It appears that it is. What are some possible solutions here. Is the water pump propeller worn that bad it isn"t circulating the water. When I look in my other H tractor radiator you can see the water being pumped. Also had the radiator redone so I know it isn"t pluged. Help would be greatly appreciated. This unit is suppose to be in a parade in a week. Thanks in advance for your help.
Try taking out the thermostat and see if it circulates. Sometimes they stick. If the entire cooling system is not plugged, then try a different water pump.
I assume it was OK before painting. If so, then something was done to block the flow. Most obvious would be the thermostat as Andy says. If the radiator was removed something could have gotten into it or the hoses to block flow. Flushing it should clear or show the problem. Good luck,
Paul
Make sure the thermostat is in the correct way. I bought an H one time and the thermostat had been put in upside down, it burned the engine up. It ran when I bought it but not good. I tore it down and this is what I had found.
I ended up replacing the pistons and sleeves along with having all the valves replaced and having a complete valve job.
I am assuming that we had circulation before we painted it. I guess I didn't look and I am sure the temp gauge wasn't working. I have a new thermostat in the thing now and it is put in correctly. Is it possible the water pump is worn out? Also the water jacket cover was in bad shape? Could either of these be the issue? Like I mentioned the water pump is turning. keep the help coming please.
