Farmall M 6 inch stroker
Rwachter13
Wanting to put a 6 inch stoker crank in my farmall m. Was wondering if it will work with no grinding and if I am able to use stock rods? Will I be able to use flat top or high dome pistons or will I have to have custom pistons made? How much would it cost to get a 6 inch stroker crank made? And finally how much hp would I gain by doing this?
Oh about 80 horsepower, but you will eventually break the web out of the center main bearing,i wouldn't do that, it doesn't prove nothing!
In Australia the powerful version was the Super AMD, which had a 264 cubic inch direct injection diesel engine. Same motor in the AW-7 Diesel, which pulled an IH 14 disc plough in hard Australian soil. Probably not many of that motor in the USA I guess.
SadFarmall
You will have to do some block clearance
and some clearance work on the cam. You
can use stock rods with a custom piston.
The piston design will depend on head CC
and compression that you want. I would
guess it might get to 80-85 hp. Crank 1500-
2000$. You will probably still be
underpowered depending on the level of
competition in your area.
