Farmall M belly pump
James MN
The belly pump on my Farmall M hasnt worked for a few years and I was wondering if there was an overhaul kit for the pump and if so where could I purchase one? Thanks
take a peek up in there and see if the drive coupling is in there first. could be somebody prior removed it. kind of a fat washer with raised slots on each side. could also be the bypass is stuck open. it is a pretty simple pump.
There is no Overhaul/rebuild kit for the belly pumps. I found a used one From Draper Tractor Parts in Wa. Think I was into it $200 including shipping(heavy).
If you go that route, do yourself a favor, and stick a couple STRONG magnets in the bottom of the reservoir before you install it. Will keep most stuff from being sucked into the pump, and shearing the shaft(which is likely what went wrong with yours).
It's not that tough of a job to do, even by yourself. Search the archives, it's been covered LOTS of times.
Good luck,
Ben
