farmall m dyno ?
henry rit
I have a 46 m with a distillate head it has 100psi of compression everthing ive found is that's high for a distallate head.Ive never had the head off to see what the pistons are. but I dynoed it yesterday,drilled the main jet out 2 sizes bigger. ported the venture out bigger and messed with the governer and removed the oil bath breather and got 52 hp it also has a lp manifold. is it possibale the pistons are over sized? also I can still pull the main jet screw all the way out under full load with no change. should I drill it bigger? thanks
Henry -
While on the dyno at full load (full throttle and engine pulled to PTO RPM), ensure the throttle plate is moved to WOT position by the governor. If not gradually increase the load until it is moved to WOT.
At this point you should be able to back the main load screw out far enough to make the engine smoke rich. If you can get it smoke rich, allow it to smoke rich for a good 30 to 45 seconds. This proves that you are getting enough fuel TO (fuel system) and THROUGH (main jet and needle/seat) the carb to adequately feed your engine. Tune for max power mixture and timing after that...
Regards,
Goldsburg
I guess for now I"m going to leave ever.ything set the way it is . I"m going to pull it for the first time this weekend I"ll see how it does
