farmall m front pedistal
hotrod60
My brother is wanting to swap out his front pedistal on his m for something he can run pressed steel front wheels he is not crazy about the dennys style he says its setup for aluminum wheels and he doesn't like the aluminum wheel look
make your own..... if you have a chop saw,mig welder and drill or drill press....
here is a pic of mine done for an H easy to make...mine weighs 23.lbs with hubs, may weigh little heavier with heavier spindles and hubs for M
kelly
this is a good setup. im gunna be getting alot of help from kelly on ideas for my M over the winter. this is a great person to work with
This is a front end for a 666. It is set up for Aluminum wheels but I am going to make one with 300 axles so that I can use 6 bolt 300 utility hubs with pressed steel wheels and 5.00X15 Tires
very nice adam,glad to see other people make them to...why buy it when you can build your own for 1/4 of the cost.......thats my motto.....you can not tell but i do have gesset on the back side of my platform also......
kelly
