Farmall m hydraulics
Jack Stanley
I have a 49 farmall m here with the belly pump. I was wondering if there was a way to rig the hydraulics up where I can run a two way cylinder. I don"t know much about the hydraulics on these old tractors I was wondering if there was a way to make this work? Can anyone tell me If it"s possible and If so what I need to do? Thanks.
Yup easy to do. Get a two way spool valve. Take one of the front hyd outputs from the belly pump, and plug it in to the in side of the spool valve. Run the return from the spool valve to the drain plug hole on the belly pump. I use a pipe tee so i can also put a pipe plug in for a drain. To use pull the belly control rod back and wire the pump on. Use the spool valve to control the cylinder.
