Farmall m ignition switch
joelu
Can anyone tell me what starter switch I need for my farmall m? It is converted to 12v. The one I was given is a dr405c. I put it on and it smokes when I use it so I stopped. Any suggestions? Thank you.
*** I incorrectly asked about ignition switch. What I needed to say was starter switch. Sorry folks.***
This post was edited by joelu on 02/10/2023 at 10:41 am.
(quoted from post at 11:05:42 02/10/23) Can anyone tell me what ignition switch I need for my farmall m? It is converted to 12v. The one I was given is a dr405c. I put it on and it smokes when I use it so I stopped. Any suggestions? Thank you.
Likes like DR405C is a heavy-duty manual STARTER switch.
''Smoking'' might indicate the new switch was ''bad'' out of the box, or that one of the terminals attached to it is contacting the metal case of the switch.
Or, perhaps, the starter is shorted, or the starter drive is jammed into the ring gear, locking the starter.
What's ''the rest of the story'', how did this all come to be/why did you initially replace the switch/was the starter working at all before you replaced the switch?
The old one stopped working for unknown reasons. I'm starting to think there might be something else wrong somewhere. I will have to look and see if something is touching.
The tractor does turn over when pressed. It just lets off a little bit of smoke at times. I try not to crank for more than a few seconds.
The problem is the replacement switch you got is
almost certainly made in what is often referred to as
the ..land of almost right.. Many only work only a few
times or last a pitifully short time. Jim gave you the
number of the ignition on.off switch. The switch you
are looking for that is sold by YT is in the link. At $15 I
am questioning the quality of it as well. There is a
company named Brillman that often gets bragged up
for having quality parts. I looked at what they offered
and theirs is only priced at $13. I guess I would expect
to pay $20 - $30 dollars for a quality switch. The
number wore out gave I believe is an original
equipment Delco number. A search with that number
does not show any actual Delco products available
which I would say is almost guaranteed to be a quality
item. It may come down to finding a tractor salvage
yard to scour to find an original. A tip is to remember
to push the button down sharply and firmly push on it
while staring. The physical pressure you are applying is
what is forcing the contacts to connect in the switch.
YT Farmall M starter switch
All u need is a good quality push switch , hopefully thats
what the case ih or Napa would sell. Them cheap Chinese
ones add lighter inside and do big last. Went through this
very same thing. Plus a low battery will heat up them
contacts and make things worst. Maybe u could wire up
one of them ford solenoids and just use the regular push
button switch like the 60 series tractors have. I got 2
sayings now. Good help is hard to find and so is good
parts.
(quoted from post at 14:40:50 02/10/23) All u need is a good quality push switch , hopefully thats
parts.
My M, 12 volt conversion, is equipped with a Ford solenoid mounted on the starter and a momentary contact switch in the steering pedestal mounted starter button bracket. Works quite well.
(reply to post at 11:05:42 k02/10/23)
I agree with Gene Bender. I think you should have your starter checked out. Not much to those switches just a set of contacts. Starter is probably dragging and using to much juice. I've seen it before on my own H's and M's.
I agree with Gene Bender. I think you should have your starter checked out. Not much to those switches just a set of contacts. Starter is probably dragging and using to much juice. I've seen it before on my own H's and M's.[/quote]
Maybe. Maybe not. I've had my hands on a few of those push button switches that were bad right out of the box. They were OK after I tightened the bottom nuts on the terminals, but got hot and smoked before doing that. Came from the land of ALMOST right. Obviously assembled by someone who didn't have a clue.
