Farmall M steering issue
dej(Jed)
M is a narrow front. When it is jacked up it steers just fine. Let down on the ground and it will only steer using a 2 x 4? Any ideas? Thanks..
The shaft (Upper Bolster) that has a thrust bearing on it (part #43) it provides the pivot point for the weight of the tractor. It is likely worn or broken. Often not lubricated. Another possibility is part 92. a deep groove bearing that controls the Worm gear.
I would expect to replase bushings (upper and lower) parts 15, 20, 44, and seals. We can help with the repair as needed. Jim
Diagram
