farmall m wide front ends
butch49
what other wide front ends will fit on farmall m
looking for a better and stronger one as i have loader on mine
spindles are shot sometimes front wheels will slam into axle have to jack it up pull linkages to get the front straight could weld it all but would rather do it right
carl
clancy montana
IHC or a Schwartz, or some make em out of truck front ends, but they look pretty crude, and don't turn to short! The Schwartz turns sharper than a IhC!
If your interested I have a wide front with regular 6 bolt ag hubs that I took off my M when I sold it its in good mechanical cond. paint not so good i would sell if your interested Im near three forks Mt
Get on from a 560 under it , pretty well both up. I used one from a 560 ih
years ago on my super Wd6. Only had to shorten the wishbone couple
inches.
The best front you will find is one from a 706,on up to a 1256. They are the same.A 1456 wide front is heavier still,it will bolt riht on. But you most likely wont find one. If you
do,it be prohibitively expencive.A Swarts or Norden,front from a 400/450;560 are all good,much better than the 'old style' tie rod out front M front. Look for a 706 front.IH made at
least 4 examples of fronts,Swarts, Norden ,and Speeco are all players.I think I have one example of each here.706 front is the way to go.
Carl,
I have a FARMALL 450 wide front I would sell. It is the original IH. It has 7.50-16 implement tires on it. It is in good condition. Let me know if you are interested and I could email pictures, I am in Montana.
