4936farmall
I have a 49 farmall m with the 4 inch stepped head over bore kit in a fresh overhaul. I also have brand new tires along with wheel
weights,haven't gotten around to filling with fluid yet. I recently acquired an oliver 2-18 trip plow and was wondering if it would
be a good match for my tractor.
in average soil conditions you will have a run away in 3rd gear. that is a 3/16 plow tractor.
Id not put fluid in tires, couple or 3 reasons,first thing your pistons stepped hp up 30% or more and second rear end n transmission is wore,andd third that M will pull 3-14 plow in any soil without fluid,1 ihc 150# weight on landside rear wheel in REALLY tough conditions.
That age it needs to slip tires just a tad,as cushion to drive train
(quoted from post at 19:11:05 10/23/19) I have a 49 farmall m with the 4 inch stepped head over bore kit in a fresh overhaul. I also have brand new tires along with wheel
That plow is a bit small for your M, but you'll still have fun.
a M is a 3 bottom tractor BUT it all depends on your ground.i have some that will stop it in its tracks with one 18.with no fluid it will be light and you will get a lot of wheel slip for me fluid is a must and your rims will NOT rust if you have no leaks and if you have a leak FIX it
Depends on the type of soil you have. Here in East Central Wi, once in a while you would see an M with 2-16s but, most of the time 2-14s. I had an M with 2-14s and at times you could roll along in 3rd and once in a while 4th but, when it hit the clay, there were time when you put it in 1st and the tires had to be loaded or you needed wheel weights.
Kind of like around here. JD 44 plow for our M. Grandpa bought a farm down the road a little afterward then bought an IH 3 X 14 plow but kept the 44 for the home farm.
I do NOT believe you. Fluid definatly and weights as well, that tractor is very close in size to a late JD A and used fluid and weights. The H we had fluid and 2 sets of weights. I want to see absoulty no wheel slip.
Well as we know some percent of slip is a necessity and the repair man well demand cash in large amounts of you dont have some
Well I am 76 years old and we always had things loaded so no slip and no problems ever. I still would want no slip as all I can see is wasted wear on tires. 44 Ford Dad bought new in 44 had fluid as soon as possible and first year he made concrete wheel weights for it estimated at 3-400# each. Never a problem, did all heavy tillage for years. Others also no slip no problems. I don't believe anybody that says you have to have slip to tear up-wear out tires to not have tranny troubles.
LeRoy is nuts! I've got books here written by Engineers that say you should have 10% slippage on heavy draft loads. LeRoy must not read anything.
I would not put calcium chloride fluid in your M unless you want it to eat your rear rims. The '51 M out in my shop has the factory installed rims on it with NO RUST, because it never had fluid. The '54 Super H has rusty rims because it had a couple patches that leaked on each inner tube. About 7-8 years ago I sand blasted and primed and painted the rims and had new US made Firestone Radial rated inner tubes put in the tires. We ran two sets of rear wheel weights on the M most of the time, and one set on the SH. Cast iron weight MUCH easier to put on/off than fluid, and to repair inner tubes too.
The transmission and final drives of tractors, trucks, cars, even motorcycles all react to the speed you try to run them pulling a load. The higher the gear, the faster you go, the less stress the transmission and rearend will have to withstand. The stress bears, gears, & shafts have to withstand is less, and they last longer. AGMA, American Gear Manufactures Association even has charts that show predicted life of the gears, bearings, and shafts in a gearbox. Roughly, reduce the load to 1/2, and the life increases TEN TIMES. So go ahead, weight that tractor WAY up, pull it's guts out! Glad your buying the parts.
Perfect example of this was the '63 4010-D Dad bought used in Dec.1968. We had a terrible time keeping it running, always something different than what we fixed before going wrong with it. According to the injection pump repairman the first guy who worked on it was a dumb jazz, the engine was pulling wide open on 3 cylinders and about half throttle on the other 3 because somebody ground up the ends of the leaf spring, so tractor made 65-70 hp. Never had a problem with the clutch, transmission or rearend. Dad used it to mow weeds one day and the PTO tried to shift from 540 to 1000 rpm on-the-go. Back to the repair shop that rebuilt the pump and majored the engine. Dad Sold the tractor to the son of a guy Dad went to HS with. He had an M&W turbo installed before he took it home. Rearend/transmission lasted less than a year. Kid actually expected Dad to pay for the rearend repair on a used tractor he abused almost a year.
Depending on your ground, you might try a set of wheel weights before putting fluid in your tires. I pull 2 14's in my ground with my un-weighted 300, and have no issues with wheel slip. What no one has mentioned yet is, how you set your plow will make a huge difference. If you set the plow to run 8" or 10" deep, your M should pull it fine. If you try to pull it deeper however, you may have an issue.
Mac
When you buy junk you can expect fail and tractor you are referincing was junk from factory to me. Could not have given me one. Had 2 tractors without fluid and did not have very long or they would have gotten fluid.
(quoted from post at 18:55:43 10/24/19) When you buy junk you can expect fail and tractor you are referincing was junk from factory to me. Could not have given me one. Had 2 tractors without fluid and did not have very long or they would have gotten fluid.
And Leroy you don't know what you are talking about. The JD A was not a match for the Farmall M. The JD A was 3783 pounds and 26 HP. The M was 4858 pounds and 38 HP. Just cause you are old doesn't make you wise. I don't like the Farmall M at all. But they were a good tractor and some are out there today still earning their keep.
The fluid argument will never end. Some like it you like. Others don't and prefer cast iron. Each to their own.
Just don't put out false info.The JD G was a match for the M. The A was a match for a Farmall H.
Rick
And you dont know what you are talking about either, The A was tested and rated at 38 HP same as the M
And the JD B was rated at 28 HP compaired to the Farmal H at 27 HP. Our Farmal H with fluid carried 2 sers of weights while the B only had fluid and no weights. The amount of fluid to replace with cast would take 4 aditional weights on each side. I don't like that abount of weights sticking out past the tire. I had both The H and B and plowed against one to other with same exact plow and same gear. The A had the fluid and weights and neighbor across fence had an M and pulled same size plows, 3 bottom.
