Hello, I just bought a 1950 M and it keeps popping out of 5th gear, also the take off in 5th gear is tremendously slow I am a John Deere guy and new to the farmall any suggestions on what needs to be done to fix this? thank you in advance!
maybe the clutch is slipping, due to being worn out. hold the brakes and see it stalls the tractor or it slips. as for 5th popping out is it going into 5 th fully.
I think it's 5th gear, thats a shallow shift,you got to take the top cover off,put it in new,Call the guys Bates Corp,1 800 248 2955, or where ever you want, its a easy two man job, two short days, they sell 200 of them gears, for road gear in a year!
In its life it was shifted from 4th to 5th gear on the fly with each shift acompanied by modest grinding if done slowly or rough grinding if just dragged into road gear. The result is worn teeth on the 4th/5th slider splines where they couple with the input shaft for direct drive (5th). eventually wear on the teeth, wear on the detent balls/spring for 5th, the center intershaft pilot bearing, and the shifter fork prevent full engagement. This results in popping out of gear. They can be shifted with practice double clutching to match trans speeds, but it is a 3 handed task. the fix can be done with the top cover (platform) off, and belly Liftall pump removed, without a split. we can help with that process with a repair manual's help. Jim
Are you starting in 5th gear from a dead stop? If so, try to get rolling in 4th, then clutch and shift quickly to 5th before releasing the clutch. If it still is slow and maybe slipping, then the suggestions of a worn clutch are next to check.
One of the main causes of them slipping out of 5th is a lot of wear on the pilot bearing for the upper main shaft of the transmission number 72 in the attached diagram. Get it in a spot where you can split the tractor. To check it you have to pull the belt pulley gear case below the fuel tank off or cover if you do not have the pulley. Then with it setting in neutral rock the tractor back and forth. The front part of the shaft that turns when you move the tractor has to be checked for up and down play. This is NOT the very front gear that is in constant mesh with the lower shaft. So you can wrap a light chain, or heavy wire whatever around it so you can pry it up and let it down. If it clunks up and down nearly an 1/8 inch the pilot bearing is worn out. Generally, replacing it will fix the gear pop out. It can be done without splitting it but the belly pump and clutch need to come out all working from the bottom. In my opinion if you have splitting stands it is easier to just split it. Either way if you have one the belly pump has to come out. If that bearing does not have a lot of play then the worn gears are to blame. Another tip is if you have a belly pump one of the coupler drive tangs needs to be vertical so the pump can slide down. And when reinstalling it can be tricky, the drive coupler puck has to be set in the horizontal groove usually on the trans shaft works best.
CNHI Farmall M trans diagram
I forgot to remind you, it's a good time to change the grease in transmission and the final drive, with the top cover off, you can get the last two gallons of crap and shaving out of there between the bull gear, you'r not going to believe how bad that is, and it still provided some lubrication. I think its 13 gallons you need .
Fifth is not two gears meshing like the others. In picture the gear on right slides onto splines in back of middle gear for top speed. Other gear is to drive the belt pulley gear box. Smaller gear and it are actually made in one piece. Small gear drives the constant mesh gear. Splines could be worn on shaft or sliding gear internal teeth. Bearing could be bad. Shift fork could have a problem.
FARMALL DOCTOR, the Ace IH mechanic that has a regular column in Red Power Magazine had an M right about a year or so ago he was working on that popped out of 5th gear. He had pretty detailed instructions of how he warmed up the actual 5th gear shifting fork with an acetylene torch and bent it for more complete engagement to stop the popping out of gear. Red Power offers back issues for sale.
One of the bigger differences between an M and an H is the M has enough low end torque that it will take off on solid level ground in 5th gear. The H will require excessive clutch slippage to get rolling, and with the big jump from 5 mph to 16 mph unless your a very careful operator, not just a steering wheel holder, most often the transmission gets forced, or ground into 5th gear which leads to popping out of 5th gear.
Dad bought Me a John Deere R diesel for MY first tractor in December 1963. I'M not real sure exactly WHAT he was thinking, He sold it before we were done plowing. I plowed the last 16 acres with the 4-bottom Deere plow pulled by the SM-TA. Good thing 5th gear in the R was only 11 mph, 5th gear starts were relatively easy. The Farmall Super M-TA I had run most of 1963 did 11 mph in the low side of 5th, the 450 Farmall that replaced the R and the SM-TA would idle off from a stand-still in low 5th and let the TA forward and cruise at 16-1/2 mph in the high side.
Guy I chopped haylage for starting summer of '68 hauled in loads with his 520 Deere. I'm not sure how he shifted into 6th gear on-the-fly, he had two of Deere's biggest Chuck Wagons to chop into, sometimes we had to run close to a mile between the field and the silos, lots of slow turns and short steep slopes to climb on the way back to the farm. I'd have used one of his 4020's.
Noticed the article, another way to move engagement of splines is to shim the spacer between the two bearings on input shaft. Front bearing sets front to rear position of shaft. Shim moves shaft to rear. Nothing will help for long if teeth are worn at much of a slant. Just make sure nothing bottoms out if moved to far.
Great thanks for the help ! Another question I do have a leak
main seal I bought the tractor from an older gentleman and it
had sat for so long the seal went bad so without having to split
it Ive had a guy told me that if you run it long enough the rope
seal will swell up and stop the leak or once they are bad do they
stay bad?
