tstarr
Hello
I just bought a Farmall m tractor I need help finding the serial # all the number I found was on the right side of block its reads
6722-DJ. Firing order
4 ( 6 8 T ) 1-3-4-2.
Thats all I found .
Its missing the plate on the left hand side.
The reason my i asking about the serial # because the over haul kit calls before a ### or after ###### .
The # where the fuel tank goes is 5-22-T
And the right side of the rear end is 6-7-T
I can tell is a 248 motor and is a 1950 model .
And help would be greatly appreciated tim
Below the #1 sparkplug (Front) There is a flat surface that has the engine serial number stamped in. That may be the clue needed as it may have a different engine than the original. Sometimes it is necessary to disassemble them then order the kit. This site sells quality components. Recommend the bore increase and higher compression pistons. Jim
