joelu
Hello all. I am back trying to get the M
going. She cranks well. I have spark at
the plugs. I am guessing it's a fuel issue
now. Any suggestions on this? I have new
gas. Sediment bowl has been cleaned out.
Thanks.
Did you try the gas in the cylinders dumped in the spark plug holes as I suggested in your previous post? Another poster suggested that the distributor cap may not be aligned properly. Did you check that and make sure the cap is in the alignment notch in the mounting face of the distributor?
Previous post
I'd start at the carb- remove the plug and see what you get for fuel flow. Should be a steady stream for a couple of minutes. If no flow could be something plugging the out let of the tank or could be the needle valve is stuck closed. How long has it been since the tractor last ran?
I removed the line from the tank into carb and have steady flow. I attached a pic of the carb. Is that small square head the plug you are talking about? If so when I remove it nothing comes out. This tractor hasn't run in a few years to my knowledge.
Assuming your spark has no issues (timing, plug wires are on right, etc., it sounds like you are not getting any gas to the carb. A cleaned sediment bowl doesn't always mean an issueless fuel supply. The tank outlet pipe and fuel shut off valve also has to be clear of debree, there should be (if your tractor still has it) a screen at the fuel line inlet to the carb), and float needle valve in the carb should not be sticking shut.
Did you try choking when you are starting? My M kind of likes the gas, and almost requires a little choking to start, even when the weather is warm.
Tapping on the side of the carb with a wrench, usually frees a stuck needle valve, if that's what it is.
If you have rebuilt the carb, sometimes a bench set of the carb adjustment screws are not close enough for the tractor to run. You might have to play around with carb adjustment. But I only advise doing this if you have rebuilt the carb, or already otherwise changed the adjustment screws. You shouldn't have to mess with those, if they haven't been messed with since it last ran.
No gas at that plug means the carb bowl is empty.No gas is getting into it. Could be either a stuck needle valve/float. Or a passage way plugged,requireing carb removal and cleaning.Give a puff of either and see if it fires. If so,its a carburation issue.
The fitting that is screwed into the carb the line connects to has a screen in it. Pull it out a check it and clean it. If when you open the gas again and no gas still comes out try this. Take a hammer and tap down on the flat horizontal surface between the 2 bolts. This is an attempt to loosen a stuck float needle valve. If gas then starts flowing out of the removed plug put it back in and attempt starting the tractor. There is a possibility that the float needle will not shut off properly after being stuck so the carb may start leaking gas in a stream. And note I said stream, there is a vent or drain of sorts on the bottom of the carb that will drip, its purpose is to drain out excess gas from over choking. At that point it will need removed and cleaned. Same will apply if the tractor does not start. However if you did not try putting gas in the spark plug holes you will not know if the ignition is working properly so you could wrongly blame the carburetor for an ignition or timing problem.
Welp i have never in my life ad and ISSUE of my bench sets not starting and running and vary little adjusting once up to operating temps , What i usually have to do is back down the ideal as i adjust ideal mixture , Load wise maybe whisker . If the puppy has been setting for a coon's age i would say that carb needs to COOK for a good day in the Kick a poo joy juice i use , it's NOT the EPA friendly stuff ya get today. and will remove two layers of hide if ya get it on you before you can make the sink to wash it off . And i work real close to the sink.
Thank you so much to everyone. She is running. The next question. It chokes out above mid throttle. Idles fairly well. Is this the carb needing adjustment?
Possibly. The fuel today is less intensely powerful than the fuel it was raised on. To see if an adjustment will cure it, bring the speed up until it is just beginning to (as you say)choke out. Then using a screw driver, turn the screw on the bottom front of the carburetor outward (counter clockwise) 1/2 turn at a time. This should enrichen the mixture. If it makes it better, adjust that until it runs best/smoothest. Then pull the throttle more open to see if it has made the difference you want. (no load wide open is not a problem, it is designed to go that fast all day. The exhaust should look clear when it is correct, and if too rich, it will start to show dark haze. The throttle should be able to be opened very quickly from idle to full throttle with no sputtering or misfire.
If adjusting the screw makes no difference, there may be deposits or flakes of rust in the carb passages. That cant be fixed by adjustment, only taking the carb apart and cleaning it. New gaskets are likely to be needed. There is a round brass tag in the carb top with a number on it. That number is used to determine which kit is needed for the cleaning. If you don't feel comfortable taking it apart, don't. The rear bolt holding it to the manifold is difficult without a bent wrench to get to the head and turn it. Farmall mechanics have (or make one by bending a cheap wrench) to make it easier. Take it to a repair shop to have it rebuilt. Ask us about repair shops if you cant find one locally, there are some we like and some we would warn against. Jim
Thank you. I did some adjusting and she runs a lot better. Not perfect but for sitting many years without running it's better than I expected. I at least have both the b and the m running now and they can be tinkered with this winter in a heated garage. Thanks again everyone.
Well, I sure hope you didn't rebuild this guys carb (not saying you did, or it was). Because it sure sounds like carb out of adjustment was atleast part of his problem.
I have an M. And my M is real touchy about carb adjustments. Might be because it has over bored pistons in it, I don't know. But the slightest turn of an adjustment screw makes big changes (on mine anyways). A quarter of a turn total, might be the difference between run, and not run at all. And no, it won't run if set by the book. I have other farmalls, with very similar carbs. But my M, seems to have the touchiest one of them all, when it comes to adjustments.
Run an undersized drill into the supply port of the fuel bowl housing . Ive notice the old gas leaves a crusty white residue blocking flow off over the years. That way you wont have any problems . Even if this isnt the problem youll have adequate flow of fuel for future.
here is the the carb adjustments just because no one ever says or even checks as to where the main needle valve is set. main is at bottom of carb. i always set it to 3 turns out on carb cleanings. check yours by screwing it in till it seats then count the turns out. i can see in the picture yours looks screwed in quite a bit. 5 turn out the main needle is completely out of the jet. so that means u can be anywhere from 3 -5 turns out depending on tractor pulling hard or yard putzing around. the idle mixture screw , the upper brass one i find 3/4turn out is pretty much max rpm. you do this by setting the idle down low like 400 rpm which is where you want the idle. then you adjust this needle back and forth for the highest rpm. rpm guage hooked up works the best other wise its by ear. then you check your idle adjustment screw to keep the idle around 400 rpm. this also prevents run on. AND of course a good carb setting is after the timing is set. she will run so smooth you will hardly hear the engine running, with a muffle of course too. and if the tractor dont run or runs funny with those settings you have other problems.
The needle on the adjustment screw may have a groove in it, or the needle seat flattened from tightening. either one causes the amount of flow to be super sensitive to needle position. Jim
---Well did you install the upgrade to that engine ?? Usually way back when the over bore kits came out a carb upgrade was also done . For the most part on a bench set i set 4 1/2 turns on the main and one to one and a half and for curb ideal I set so i can see a tiny bit of day light and normally that set usually gives me a 600-700 RPM COLD START IDEAl with out fussen tryen to keep it running as it warms up . I do a lot of carb work around here and have been working on carbs now headen into 61 years working on carbs . I think i have it down pretty good . People BRING the carb to me and when done i install and set . Ya never know what your going to find when you open one up , One never knows if someone put a drill bit to the main jet and just running a drill bit thru can really mess you up.
