Farmall MD 12v generator system
Jvoss
Recently restored my 1951 Farmall MD. Had the generator rebuilt, brand new voltage regulator and brillman reproduction wiring harness. Everything is wired and ground like it should be I think. Gauge shows discharge with tractor off and lights on like it should. Good battery. Fired the tractor up. Used a jumper wire from the B+ on reg to A side of the generator and got my little spark and it started charging. Battery was already at 12.7 volts. As I check the battery volts while running they slowly climb past 14volts. Slowly climbed up to 16volts so I shut the tractor off. What’s the charging ranges for these regs? Maybe I missed something I’m new to generator systems? Could they have set the 3 brush wrong inside the gen?
The generator is controlled by the regulator. If you jumped it while running, it was the wrong thing to do. It should be polarized when turned off. I cannot say what is wrong, but the regulator field control grounds the field to make it charge. If the F terminal (on either the regulator, or the generator got touched with battery volts with the regulator connected to the gen. It may have welded the field contacts in the regulator. Your call, but were it mine I would take off the cover and see if the field regulator relay had stuck points. (but I have been around them since 1957) Jim
I didn’t touch the field on the reg or the field on the gen. I was told jump the bat on the reg to the A on the generator. Little spark and it started charging.
I was told anytime you break the charging circuit you have to re polarize the gen that correct? If I break the ground from the battery I could start over. The contacts didn’t get welded.
Thanks for answering in real time. The generator field poles (made from iron, and what the field coils are wrapped on) are magnetized by the polarizing voltage through them to ground through the regulator points. Once magnetized, and charging, they stay magnetically polarized for a long long time. I have seen them stay charged while on a shelf in the garage for 4 years! So removing the battery connection while running (though not a good idea) or when stopped, (No harm there) will not change the polarization, or eliminate it. Voltage climing above 14.6 will not do. If the voltage regulator has a warranty, (most don't) use it. Jim
Jim: My understanding is that a 3 brush generator has a simple cutout, while a two-brush uses the regulator. If a three-brush generator is producing too high a voltage, then it sounds like the 3rd brush is in the wrong position. On the other hand, if this is a two-brush, then the regulator should be opening the ground from the field coil when the voltage gets high enough and grounding it instead through a resistor to reduce the field current.
If I am missing things or confusing apples and oranges then let me know. I honestly don't know what would happen if a 3-brush generator was used with a 2-brush regulator. Thoughts? Dave
A three brush generator acts just like a 2 brush. The difference is that a three brush can be limited in output to accommodate manual charge rate (the H or D or B positions of the light switch, all have full grounded field. The L position runs the Field through a resistor to limit charge to about 2 amps above ignition draw. This simple system was used until about 47. I think tractors in the 50s had regulators. The 2 brush generator will put out its max amperage (usually about 15 amps) when full grounded field, so they would overcharge the battery even if running on L. SO a 2 brush field hooked to a 3 brush gen (with the brush set for max output would be regulated correctly if the voltage relay in the regulator was working as designed. Jim
Thank you for you response. I will look into that stuff. Just out of curiosity could a ground issue cause anything? I made sure the battery ground was free of paint but where the reg mounts to the tractor it has fresh paint under there if that affects anything?
Jim: Thanks. It is unclear from the original post if the generator is 2 or 3 brush, and what regulator it should be used with. From the year it should be two brush, and my understanding is that the 2 brush is used with a regulator which should automatically drop the field current when the voltage gets to the proper voltage. Is it possible there is a mis-match of regulator (or cutout) with generator? Also, if the field circuit is grounded somewhere, then even if the regulator field relay opens (which normally brings the resistor on the bottom of the regulator into the field circuit), the generator would still be getting full field current as the resistor would be doing nothing--the field current would be shorting to ground. I could see this causing an overcharge/overvoltage situation. Am I thinking about this right? Dave
I will just add that IH used a voltage regulator with the three brush generator for years. They normally did not have an adjustable third brush like the original generator that used a cutout onlyu along with high low charge rate on the light switch. My 52 H has a three brush generator and regulator. Original generator, don't know about regulator but it works fine and I have adjusted it after I went through entire tractor.
Also, easy to tell if regulator is causing the over charge . Just unhook the field wire at the regulator and if it quits charging you know problem is in regulator. If it continues to charge, you have problem in generator or wire to generator field.
And only polarize while shut off like Jim said.
Also since I had already polarized the gen with it running do I need to do anything over since it was supposed to be off? Or will it stay polarized or hurt anything since I did wrong the first time
