Farmall rims
mcrow4117
I posted this in the farmall section also but I am restoring an h and the front rims were not in good condition. I found some at a salvage yard I. Good shape but my question is do the clamp style rims need something welded to the rim on each side of the clamps?
Its a little bit of overkill. There's no reason for the rim to rotate on the hub unless the lugs are allowed to get loose. I have seen it done, though. Depends whether you like the looks of them or not.
(quoted from post at 20:12:27 09/11/17) Its a little bit of overkill. There's no reason for the rim to rotate on the hub unless the lugs are allowed to get loose. I have seen it done, though. Depends whether you like the looks of them or not.
That was my thoughts as well. But wanted to make sure. Thanks
I have found some that had a small piece added to the rim that the notch for the center cast to fit only one place was all that was needed. Came from factory that way i dont remember who made those rims as lots of rims did have the manufactures logo on the inside of the rim.
