Farmall Rims
The 11.2 is on a 10" rim, and I think the 13.6 should be on a 12" rim, so the 13.6 on a 10" rim won't be right by any stretch of the imagination, but in a pinch it can be done. The 13.6 is a taller tire than the 11.2, and squeezing it onto a narrow rim will make it stand even taller, so your tractor will end up being a bit lopsided.
If it is an H, a 12.4 is ok, 13.6 on that size tractor is overkill. If it is an M, it likely has 11 inch rims, 13.6 will be fine, the 11.2 will not transfer all the HP the M has to the ground.
It isn't the tires, but the rims!!! I bought a set of 14.9's on 11" rims. Did it work...yes. Should it be done...no!
The only way for us to truely know is to determine how wide your rim is. Telling us what tractor it is on is a great start, but not a dead giveaway at how big of rims are on the tractor.
