Mike Wheels
I bought a Farmall SC with a belly mower on it. Previous owner always pulled the negative ground clamp off the battery. To prevent it from draining. Its still a 6 volt system, negative ground. I am in the process of replacing the old frayed wires on the generator and the system. Is their a wiring diagram that would show me how and where everything is hooked up? So I can double check that things are right. I probally should go out and get a new multi-meter first, and see if the generator is charging. Before I get too in depth. As now would be the time to re-wire it all for 12 volt if the generator is bad. So Im looking for help to find a wiring diagram. Also I thought 6 volt systems where positive ground. Can they be negative ground as well? As mine appears to be negative ground. What is the normal voltage a generator should put out? Thanks
