Farmall Starter Tank
mfernandez
Need help identifying which tractor this tank went on. Thanks in advance.
Could have been used on a number of the gas start/diesel models....MD, 400, 450, WD9, etc. as the gasoline tank.
Ben
Looks like the starter tank for Farmall H or M, W-4, W-6 or W-9 with kerosene or distillate engine or even WD-6 or WD-9 with Diesel engine. The W-4 tank, and I suspect all the others, has only mounting bracket on one side as it attaches to the stand for the instrument panel (oil pressure and water temperature) and which also supports the steering shaft on the Farmalls.
When I built My HTA I used one of them for the power steering fluid - and used a 1943 H hood. a 350 farmall power steering pump -- worked perfect !
