Farmall Super 450 value
Forum,
A friend has a Farmall Super 450 she wishes to part with. Need to know the value. Two years ago everything worked well. Any and all thoughts welcome.
Sorry, but you will have to find out what it really is no
such thing as a ..Super Farmall 450.
There is the row crop style Farmall 450, 1st link and
the International W450 standard tread tractor or
Wheatland, 2nd link.
Knowing the condition of the rear tires and paint is
very helpful. Also if it is a Farmall knowing if it is equipped with a Fast Hitch helps judge the value. Pictures will highly increase the pricing
accuracy.
Tractordata Farmall 450
Tractordata International W450
Thanks for the reply.
I am not familiar with Farmalls but will describe as I saw it last. It is a wide front with the high end front end set up. Tires all the way around are in good shape. Right rear will need a new tube as saline solution has corroded the valve stem. Paint job is rough. I am not familiar with quick hitches so I will take pics this afternoon if I can contact the owner. Probably easiest if I could send the pics via cell phone. I am not good at pics on this system. Thanks.
To me and that is all that would matter. A 450D running in decent shape I would not pay more than about 25-3000 for. Probably on the cheap side, but with all the choices I have for tractors to use already it is just not to valuable to me. It would have to be a hay rake or auger tractor all the field equipment is already getting to big for the 1466. I know this is not really what you want to hear but that's all I would value it at.
And gas or diesel is another thing worth knowing. If she is okay with you going over there you should take a set of jumpers or a good 12 volt battery. If it is a gas tractor you should tell her to give you a $100 to try to start it for her. If you get it started the price of the tractor immediately increases $500 to $1000. The Fast Hitch will resemble a 3 point to a degree. It will have a rock shaft with arms. Connecting to the arms will be vertical lift rods. They will go down as a normal 3 point to the lift tugs. The lower tugs will have receiver sockets that likely will have the draw bar slid in them. In the link see picture 11. If you get the picture okay I will do the picture posting for you. Go ahead and contact me through the site email. That way the picture transfer will be between our personal emails.
Farmall 450 with Fast Hitch
