Farmall Super C Compression???
Anonymous-0
I just did a compression test, all four cylinders are reading right around 150 psi. I thought that new the tractor only had around 115psi. I pulled the plugs stuck in the tester and this is the reading I have been getting. Am I doing something wrong. We just bought this tractor so I dont know much about its history. I have been using a craftsman type screwin tester. Thanks for your help.
Cody
I would just assume that it had an over bore kit, maybe M&W's also, and use it until you have a need to open it up, to know for sure. That is about where the compression is on my high/domed piston over bore kits are.
