Farmall Super C Diff.
Tinks
I am tring to get the rear diff. cover off of a Super C but it does not want to come all the way off. I have all the bolts out and it comes up about a 1/4-1/2 inch only. what am I missing. Thanks for any help.
If you are certain you have all the bolts out, then it is either sticking on the locator dowel pins or one or more of the shifter forks is worn so badly it/they are sticking to the gears. Try looking around the edge for the dowels, and spray with lube, if still nogo, try shifting it in and out of each gear while trying to slowly lift it. Good luck.
