Farmall Super C hydraulics
M Nut
Hi Guys,
Needin a little help. Actually, needin to know if it can even be done. My neighbor has a Super C farmall without a fasthitch. He is trying to mount a John Deere #5 mower onto it. He has a hitch made that will work, but he (nor I) doesn't know where a hydraulic outlet can be installed on the tractor to run the hydraulic cylinder that raises and lowers the sickle bar. It has the cultivator arms, and there is a hydraulic pump mounted near the distributer that has two steel lines running back to the box that the cultivator arms are mounted to. Is there any way to hook up an hydraulic outlet to this tractor?
Thanks for any help!
There should be a socket type of plug on each metal hose where it meets the lift arm box (that is the oil resevoir). The high pressure side would be the place to add a hose.
There is a remote HYD. Valve that mounts between the lines and the tank where the arms are. Should be able to find one pretty easy on here or in a tractor junkyard
Larry
