Farmall Super C points
JustahobbyMn
Replacing points on my super c. When I took it apart I
cannot remember exactly how the points go together.
Does the condenser wire and the points spring clip tang
touch on the little bolt coming in the side? Or does the
little square nut go in between them? I had them
touching when it put it together and I get absolutely no
spark.
Sometimes the simplest things drive us crazy.
Looks to me like you have it correct.
As long as bolt, point spring, and condenser wire are in contact with each other AND insulated from the case all will be well.
Hopefully that picture was taken before you finished setting the point gap, if not that is way to wide. It should be 0.020 inch. Also the points rubbing block that hits the cam ..thing with 4 bumps.. should be on the very top of the bump. I agree with wore out that it looks correct as far as your point spring strap and condenser lead connection to the pass through terminal. I hope I am correct on this it has been a while but the square is there to fit in a square indention in the insulator of the pass through terminal to keep it from turning. Do you have a test light or meter. Hopefully you have power to your coil when the switch is on check that first. Then when working correctly the terminal on the side of the distributor should show power when the points are open or not contacting. If it does not there may be a problem with insulator for the pass through terminal. And conversely the terminal shows no power when they are closed, grounds out. Try not to leave the switch on very long with them contacting and the engine not running. Also smear one BB sized dab of grease across the other three bumps of the cam lobe.
The adjustable piece (that you move to adjust point gap) is grounded when you tighten it's screw to the distributor housing. Thats the only part that should be grounded. The rest of the points (the large springy part of the points) needes to be un-grounded. The point spring, condenser wire, and the hollow insulated stud going outside to the coil wire on the
outside, should all be ungrounded. The stud brings coil juice inside from the outside wire. It can't be grounded. Alot of people make the mistake of tightening up the condenser wire in a way that the wire tab connecter touches the housing, grounding itself. It won't work that way. It can't touch the housing grounding itself. Point spring, is the same way.
It wouldn't matter if the little square nut was between the points spring and the condenser lead. They would still be connected electrically by the conductive steel screw.
Don't mess with the square nut, though.
It will work if you set the points like described. There are several things actually jury rigged on that stud though. First off the insulator is broken. It is supposed to have a shoulder on the top end and points fit under that to help position the points properly. Also, the square is built onto the stud and I see it is cocked a bit as it should fit into the insulator square.
There is supposed to be a flat washer, cut washer and hex nut on the stud tightening the points and condenser to the stud.
I would bet I have replaced with new because of being broken that insulator on 90 percent of the distributors I worked on. It seems just to come natural to break it off when installing a set of points.
Then after tightening that inside nut, you loosen the one on the outside of distributor to relieve and twisting stress on the spring on points, then tighten it up again being careful stud does not turn.
I know, picky, picky, but , that is the way it is supposed to be.
And another thing, I always remove the distributor when replacing points on those horizontal mounted distributors you can see what you are doing and also check out the weights and springs below the plate.
I put a dab (suggest) of ignition grease on back side of the points cam lifter ,like the magneto book shows . Get those little capsules or packages at auto parts if you dont have any grease .
Spring pressure on the points is important .
The points if done correctly will give years of flawless service .
Good luck .
