FARMALL SUPER C
ansavist
with the farmall c running why doesn't the ammeter gauge needle show some positive charge but a multimeter will show 7.14 i tried another ammeter and also a new one same results but if you bypass the voltage regulator the ammeter will show a positive charge. how is that possible. what is wrong
thanks for your answer but if the multimeter is showing a charge of 7.14 a full battery is 6.3 then the ammeter should show a charge not standing straight up in the middle correct or not
That's because the battery is fully charged. You can't put anymore amps in. The voltage is the equivalent of pressure trying to cram more amps in but the battery is full. Kill the engine, turn the lights on for 15 minutes. The amp meter should show discharge. Then start the tractor, then you should see a charge as you used some amps. This is my opinion of what is happening..
A fully charged 6v battery has a standing voltage of 6.3 volts. Charging systems with a voltage regulator (yours) control the charge voltage to about 7.2 or there about. This amount of over voltage will not increase the battery level of charge because it is charged. The amp meter is showing nothing because the battery is taking nothing. The alternator in modern vehicles puts out 14.4 or so volts while running. a 12v battery has a resting voltage of 12.6.
In both cases the batteries are full. Charging with more voltage just heats up the battery and begins to destroy it. Charging with less, does nothing but increas the time to full charge, and if just above 6.3 will not charge it enough to keep it charged. Light bulbs are designed to operate at 7.2 to 7.5 volts with a good output and life. In cars and trucks they are designed around 14.6 to 15 volts of continuous operation.
If you turn on the tractors lights, and the ignition coil when running, the needle will again stay at the center. The lights taketheir current before the amp meter and only the charge into the bat and out of it are shown
LEave the lights on for 4 ro 5 hours and go back and see what happenes. Bet the needle goes positive then.
i agree. but in my way of thinking, a electric system is either charging or discharging regardless if the battery is full or not. it might be just a tiny amount but as long as the gen. is putting out more volts than the battery has in it the ammeter should show a charge, how much is controlled by the voltage regulator.
(quoted from post at 07:24:39 10/12/22) thanks for your answer but if the multimeter is showing a charge of 7.14 a full battery is 6.3 then the ammeter should show a charge not standing straight up in the middle correct or not
6.3 is the RESTING voltage of the battery. That's after you shut the tractor off and leave it sit with nothing on for an hour or so.
Is the 7.14V reading with, or without the regulator bypassed?
Try the "shut the tractor off, turn the headlights on" test. Does the meter go to negative?
AMP meter vs VOLT meter. It is showing a charge, if its working. May only be 1 amp or so. (Maybe a couple of more.) Youre worrying over nothing.
If the test of leaving the lights on for a period and then starting it and it shows a charge at that point do this. Quit worrying about it and use the tractor be happy that your charging system is not cooking the crap out of your battery. If you want to see that ammeter swinging around convert it to 12 volts and install an alternator. Did I say use it and be happy? My two cents! You sound a little like the guy with the post on the UD-14 engine who has to pull is apart to take sonic tests in the cylinders, must be an engineer. ; > )
